Last summer AC only blowing about 60 degrees. I recently took the Elky to the AC man and he installed new compressor and dryer, and of course, evacuated and reloaded the system. I turned it on and was getting 41 degrees output....yeah! Next day, no cold air. I called the AC man and he said to turn controls off and on and then it worked. Today same thing happened, only I had to do this several times before the AC would kick on. I tried Max setting, normal, and bi-level settings back and forth several times but no cold. Turned everything to off and then back on several times and then it finally kicked on. Vent doors and blower motor work fine.
Is there a bad contact Or vacuum line on the head unit switch. What do I need to look for?
