So quick wiring question. We swapped out the engine from the 305 to a 383 stroker. New carb, no pollution controls. No ECM. Changed the compressor to one from a 91 Chevy PU (so it would work with the serpentine system)
In looking at the wiring diagram, the way I'm reading it is, the only thing in-between the hot lead on the clutch and the power (from the control panel) is the pressure cycling switch on the drier. Am I right? Also the stock connector to the clutch had a diode across the positive and negative which the new connector didn't have. It it ok if that's not on there?
Thanks!!
Frank
Thanks!!
Frank
