1 - 11 of 11 Posts
Hey Guys i've got a question. I've got a 1987 El Camino, and i'd like to make it a low-rider with some airbag suspension on all 4 wheels. I cant' say that i know too much about suspensions. I guess what im asking is what should i look for. Like what are some good sites, brands, etc. Thnx
well looks like i be needing some money for air suspension. would it be possible to just cut my springs to lower it til i get air-ride? how exactly would i go about doing that would ya think. thnx again.
well thnx guys for the tips. ill have to check into that. how hard do you think they would be to install(those belltech front and rears)? thnx again
Rear springs are easy to do in under an hour. Spindles may take an hour apiece barring any unforseen complications (like finding a bent OEM upper ball joint that you have to grind the rivets out of in order to change it)
A new front end alignment is necessary too.
:mrgreen:
Discussion Starter #9
alright thnx. and those bell tech springs those are permenant there is no way of adjusting them? thnx again
airbag ?'s
if ur looking for a good fast setup, go with a 6 gallon tank a viair compressor , 1/2" lines all around!! no reducing!! 1/2" parker gold valves rated for 300psi an adjustable psi switch 75 - 400psi and slam specialties airbags, and also quick fingers. and whatver u want to add on. 8) 8)
1 - 11 of 11 Posts
