I'm lookin for someone who knows how to install a shift improver kit? Anywhere around Phoenix, Az? I live in Apache Junction but am willing to drive an hour somewhere??
As well as doing minor things like replacing the kickdown cable/bracket
As a college student, its tough on the pockets i can do it but its taking me longer because i keep wondering "Is this the right part?" i'm currently low on funds, and i dont have the luxury of buying something just to find out it isnt exactly gonna work or fit on my car...
since i have both edelbrock manifold and carb, i cant take the factory bracket and make it fit...
currently the bracket for the throttle and kickdown is like bent out of place, the kickdown is only 50% functional because of how bent it is as well as bad cable
ofc i pay green cash :) right now i've been quoted $350 just for LABOR.. i am not exactly sure but i would think its a bit too steep
that is kinda high to just install a shift kit, it shouldnt be any more than 200.on a early car like yours i going to assume it has a non overdrive trans and those are fairly simple to do. the kits give you pretty good pictured instructions.but if your not comfortable dont do it.
Holley makes transmission/throttle cable brackets. That's what I use. Check out their online catalig.
Jack
There are aftermarket TV cable brackets that are bolted down with the driver's side carb. bolts. Olds Q-jet / 200-4R vehicles used a similar setup in the 80s. Go for one of those that works with your aftermarket carb.
