1 - 12 of 12 Posts
Bought what is supposed to be an '86 Elky TBI unit from a wrecking yard in Mass. Received it and am fairly sure it is out of something other than a Elky. The unit is 7.5 inches long from the lid to the bottom of the pump; the float is .5 inches below that. The fuel lines hang straight down from the top without an angled turn like a carburetor sending unit; the formed rubber hoses were chopped off but enough was left for the lines to do a 180 turn and pass by the steel lines going the opposite direction. My guess is that it would work but not with less than 1/2 - 3/4 of a tank of gas. The seller refused a return of the unit and I have filed a dispute with Visa. I going to need a picture of the correct unit to argue my case.
Thanks in advance for any help !
leadmine
i hope this helps its from an 85 but dont remenber if 17 or 22 gallon but it is only 1/4 in shorter than the one i just took ouy of my carb equipted 22 gallon 86,so i would asume its 22 gallon
That's what I used in my LT1 swap. Then the fuel pump from a TPI Camaro attaches right to the fuel feed pipe.
And the gas gage reads 1/4 when the 22 gal tank is half full.
the sender pic is of a original efi elco not an aftermarket. the j a that removed it from the car cut the pressure line with the sawzal he used to remove it from the car. it read fine but is damaged
sender
dixiemonticarlo.com has the sender cheap
The eL Camino store has a good picture. You could hang the level gauge with a short bake line welded or brazed to the top of the sender mounting plate.
1 - 12 of 12 Posts
