1 - 17 of 17 Posts
I live out in the country,and everyone,I mean everyone in my neighborhood drive trucks.
I'm buying the Elky mostly for utility...traveling and shuffling parts to the machine shop,bringing parts back from Pull a Part,etc.
Looking for thoughts about lifting the truck and adding some big tires and a big block motor.
Anyone have their Truck lifted?
That looks like an Elco sitting on a Blazer or truck frame. Complete with 4wd.
Looks pretty cool as a 4x4. Lots of work. It would probably be less expensive to buy another vehicle unless your a fabrication wizard.
Good luck
~JM~
My boy has a 5th gen with a six inch suspension lift
What parts are used and what OEM components need to be modified? I think a little bit of a lift on an El Camino could be pretty sweet. I wouldn't be interested in anything nearly as extreme as 6" though! Perhaps 3 or 4 at the most. Just enough to give a little more ground clearance and allow bigger tires.
Wit the 5th gen. If u want a 4wd elky. U get an old suburban n they almost bolt direct on from what I've been told by someone wit the blueprints. But wit a 74 im not to sure but I would try goin in that direction. I already want to but not enough $ to build the one I got and a 4wd elky.
Some nice HD springs and shocks would give it a better stance along with being a little more "truckish". Maybe some air bags in the rear for some real heavy loads. Plus a truck tire like a BFG All Terrain, it's also a 4th gen so it can fit some pretty beefy tires as is. As much as a lifted truck might be cool, it's not practical for a work vehicle.
1 - 17 of 17 Posts
