1 - 16 of 16 Posts
it is used for the return hose from the water heater ( instead of it going to the water pump). You can run the hose to the radiator, and screw a plug into the water pump.
since it's from AZ but NOT electrical, you shouldn't have any trouble with it.
:poke:
Okay can i just plug it at radiator with cap on it from Autozone and i dont think i have a water heater
Discussion Starter #10
If this is the water heater that runs in line from fire wall two heater hose to Intake/ water pump??? No i dont have a water heater .
Deputy Director Region 6
Do you think he meant to say heater core ? not water heater ? :dontknow:
My heater hose connect to Intake and water pump so what do I do about the nipple on the radiator ???
see post #9 above, or see post #3 above. Those are your two options. Either one requires you to buy something- either a cap at autozone or a pipe plug at home depot.
1 - 16 of 16 Posts
