Last wednesday i changed 6 spark plugs on my on my 1984 elky w/ a 305. they were all fouled so i know the ones for 6 and 8 are. it looks like it will be a tight sqeeze to get them out, any suggestions? it has A/C (which seems to be in the way). i was wondering if anything need taken off to get to them.
thanks in advance :) :) :)
try jacking the right side and removing the tire. you maybe able to get access through the fenderwell openning. plug sockets with a swivel end built on, or wobble extensions may also help. Or you may have to resort to a standard plug socket with a wrench to fit the hex on the end. Good luck and may the force be with you :)
Vendor
That works, but I usually use a plug socket, one inch extension with a wabble head ratchet.
Moderator
It is a tight fit but I am able to get back there with just a plug stocket & rachet.
Thanks for the tip.... looks like the two bad guys are on the passenger side. I have been putting off changing plugs because they looked too hard.
They may be easier to reach with the wheel removed. Great tip
You can access the plugs with a regular 3/8 drive plug socket and ratchet, but you MUST use just the right length extension. You will have to experiment with the extension length, but one a couple inches long provides enough clearance to do the job, but it is a tight fit. I had to buy a short extension just for this purpose.
