Back glass interior trims - 67
93 views 1 reply 1 participant last post by  1slogoat
#1 · (Edited)
I have the set of 4 plastic trims that goes around the tack strips on all sides of the glass which also hold the headliner in place. However, on the bottom area by the tray I see screw holes for a molding or retainer that is missing. I've searched all over the place online and can't find it. Due to the urethane bead, there's no way to attach the lower trim without something screwing into this area.
Does anyone know if this is reproduced? Or what it is called to see if I can find a used one? I will be painting this area and want to figure this out before I do so.
Thank you!
