Can I ground my battery on a motor mount bolt?
10/4 thanks, ill do that and add some from the firewall to the block.I don't know how many other grounds you have (eng to firewall, batt to body, etc.) but this as the main ground needs good contact with engine side. A rubber motor mount with steel sleeve probably doesn't ground to engine. The engine needs a good ground for alternator, spark and sensors current flow.
they sell rolls of the braided wiring flat strap stuff. when I had my Ford Crown Vic Police model, they had added those ground straps everywhere; hood, trunk lid, engine, and actually doubled it in some casesYou can, but it would be better to ground to the engine block. On some older Chevy cars they had flat metal straps from the firewall to the valve cover bolts to help tie the body to the block for improved grounding.
Is it better to use ground straps instead of regular wire?they sell rolls of the braided wiring flat strap stuff. when I had my Ford Crown Vic Police model, they had added those ground straps everywhere; hood, trunk lid, engine, and actually doubled it in some cases
You can but it should be on the block side of the motor mount. Going to the frame side can cause electrical gremlins as your starter motor will try to draw ground from all systems to complete the circuit. Main ground should always be direct to the block withs a separate battery ground going to frame.Can I ground my battery on a motor mount bolt?
