Haven't been on the site in quite some time! But SteelBeast has kept me updated on a lot of great things that have been going on with ECC. An awesome club to be a part of.
I have an aluminum Jegs radiator and I was advised to have it welded to stop the leak (which has progressively gotten worse), does anyone know of a shop or person that you would recommend? Preferably in the Ft. Worth/Arlington area, if possible of course.
Thanks in advance!
Did you call Jegs, they may know of someone in you area, that does repair for them, that covers there products. Just like my create motor, they had a gm dealership that covered gm create motor repair.
Just wanted to add my 2 cents. Just be careful when welding, as the heat can cause other metal fatigue problems in the surrounding areas. I hope that is not the case, just wanted to make sure you check it out before you spend too much for welding repairs.
I'll ask my buddy at the shop and see if he knows anyone. I know that there's a radiator shop in downtown Garland but I've never used them.
