1 - 16 of 16 Posts
Last year my 84 Air Conditioner was getting touchy.The fan sometimes would not work on low.So a light tap on the blower motor,and everything was O.K.This year (Yesterday) it only works on high.No medium or low.Tried tapping.Should I get a bigger hammer or,is it time for a new blower motor????:violin:C.J.
Hey C.J. if you were tapping on the motor to make it work, its a goner.
Time for a new one.
I did not think that a real Marine like you even used an air conditioner :dontknow:
I'd look at the blower motor resistor before I would change the motor.
Discussion Starter · #6 ·
Lenny,it's not me ,it's tootie!!!!!:let_it_all_out:She said "Do you want to ride all the way to Ocala with the windows down"?
Discussion Starter · #8 ·
O.K. the resistor is good. I ordered and installed a new motor.STILL NOTHING on LOW or MEDIUM.Fan only works on HIGH.Should I try the switch??:let_it_all_out:
Discussion Starter · #10 ·
I will do that.thanks for the info.I grew up and worked in G.R. Retired Steelcase driver
A few minutes with a Volt-Meter to trace out the Circuit is faster & cheaper than throwing parts at it!
Back to Basics...Start by checking all Grounds by doing a Voltage-Drop across them...Clean them just for drill. Then go to the Fuse block and work your way to the problem...
Discussion Starter · #14 ·
And the winner is:nanawrench: I replaced the motor.(still the same) I replaced the resistor (still the same) I replaced the switch,(still the same)Would you believe THE RELAY!!!:beer: I do have a couple of slightly used New parts for sale.Thank's to everyone that responded. C.J.
Blower motor
Semper glad your issue is solved. Ive worked near steelcase for 35 years, always loved the looks of there fleet. Was sorry about there business issues. Have alot of coworkers that transfered to them for the bonuses and lost their jobs a few years later. A real blow for the local economy.
1 - 16 of 16 Posts
