brake light on dash is constantly on. Just had a front brake line replaced when the light first came on it went out when fixed now it is on again. Cannot see any leaks and the fluid is full:dontknow:
Follow the lines coming out of the master cylinder down to the side of the frame where they all connect to a distribution point. In the center on top of that you will see a little black rubber cap with a brown or tan wire coming from it. Un plug it and see if the light goes out. If it does follow the instructions above and bleed the system.please pardon my ignorance but where is the valve located
