Installed p/b booster on 66, original style, chrome reproduction. The threaded rod that attaches to the brake pedal is either too short or the fitting it too short for the pedal to travel all the way back to the bumper. I adjusted the switch all the way towards firewall, but it is still a little short. Brakes lights do not always go "off" when releasing pedal. First, I have no return spring, and not even sure where it should be mounted. Before the booster install, it worked fine w/o a return spring. So, my ?'s are
1. Can I get a longer (1 to 1.5 in) rod that comes out of booster? Not excited about taking booster off and taking it apart.
2. Are there other fittings that I can put on rod, with out fabricating one. I'm not a fabricator, but may have to try. Also, fitting is all the way to end of rod.
I have tried contacting ebay seller of booster several time;;;;;;no reponse
Some other info, this was originally an automatic, previous owner converted to 4sp from chevelle SS, 1966, from what he told me. Not sure if this makes a difference. My son's 64 had an aftermarket booster installed(automatic), and it fits and works great, almost too touchy.
Any help, suggestions, stores to look, etc etc......all help is greatly appreciated!!
On a side note, it looks good! Old m/c looks like crap, but booster is nice!
