C clips are sometimes annoying. I found the easiest way is to leave the tires on. Then I slowly spin the tire while slamming the axle in as far as it will go. Eventually, when you least expect it, it will fall straight out.
Hopefully it works. There’s probably a more proper way to do this, but I have no idea. I hammered mine out when I got it stuck.Right now im trying the glue thing if that doesnt work ill be hammering it
I’m assuming that he meant the broken bolt is spinning, but can’t pull it out given how small a bolt it is. But yes, if there’s a posi putting pressure on the pin, you’d rock one of the wheels back and forth while forcing the other tire to not spin, while also pushing the pin out.I may be missing something, but if "All the threads are on the bolt but now the pin is rotating" then the cross pin bolt is no longer holding the cross pin in place and you should be able to get the cross pin to come out the other side of the carrier (nothing should be holding it in place with the exception of a posi rear end where the spring pack is putting pressure on the side gears).
