I dont know for sure if the seats would be a direct bolt in or not,, but the center console would take some fab work,, close in the same years so it may look "factory",, post some pics when ya can,, can you weld and fab some brackets for the console?? The shifter should be good on the center console if your bud gives that with it,, but you will have a column shifter and a center console one,, you can get a I Did It or Flaming river column if you go with a console shifter,, sounds like a good swap IMO.. Matty man
