Engine specs: 305 from a 5 speed manual 91 camaro. Originally tpi but converted back to carb setup. Mild cam, edelbrock carb, and an electric fuel pump are about the only upgrades.
Trans and Rear: 3 speed TH350 from a 77 Nova and a 10 bolt posi rear
Suspension: Stock
Body: Original paint, and what seems to be some Choo Choo options (hood, ground effects). The nose was swapped at some point, there is red paint showing in some places.
Interior: Original except for the stereo system and a manual choke mounted under the dash. Stereo consists of a Pioneer head unit, Pioneer 6X8's and a 800 watt amp mounted on a custom box, as well as a Pioneer 10 inch sub behind the seat. Also XM radio equipped
Other: Exhaust is true duals with glasspacks dumped before the rear axle.
Pictures:
Suspension: Stock
Pictures:
