1 - 3 of 3 Posts
I have an 83' El Camino w/ a 305, w/ a rochester quad carb. After screwing the air fuel mixture screws all the way in, how many turns out do you do to get an optimal setting? ThanX
After I rebuild a CCC carb I preset the idle mixture screws at three turns off of their seat. After the engine is up to temperature and the ECM is in closed loop I use a scanner to monitor the dwell and do the final adjustment of both idle mixture screws (in equal increments) to get the dwell as close to 30* as possible. A vacuum leak or a bad oxygen sensor will make it impossible to set the dwell to 30*.
Here is a good article on how to do it:
http://tlentz.oldsgmail.com/howto.html#Mixture
:mrgreen:
1 - 3 of 3 Posts
