$ 80.00 Free shipping lower 48 !
Very low run time ,i installed this for a customer and swapped it after about 400 miles ,
Description of CRANE 100172
Part Number: 100172 Grind Number: 274 HO6
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 ROUGH IDLE, MODERATE PERFORMANCE USAGE, GOOD LOW AND MID-RANGE TORQUE AND HP, MILD BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, 2600-3000 CRUISE RPM, 8.75 TO 10.0 COMPRESSION RATIO ADVISED. BASIC RPM 2200-5200
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 300 @Valve 450 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 300 @Valve 450
Rocker Arm Ratio 1.50
CamTiming: TAPPET @---
Lift: Opens Closes ADV Duration
Intake --- --- 274
Exhaust --- --- 274
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 105 [email protected] 1.700 or 1 45/64
Open 265 [email protected] 1.280
Recommended RPM range with matching components
Minimum RPM 2200
Maximum RPM 5200
Valve Float 6500
CamTiming: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 7 BTDC 31 ABDC 102 218
Exhaust 39 BBDC (1) BTDC 110 218 First $ 80.00 0n the Cam !!! thats a steel its in nice shape and all lifters are marked as they cam out ! CALL 409-256-2025
:texas::beer::driving:
262-400 C.I. V
Intake --- --- 274
Exhaust --- --- 274
Part Number 99848
Minimum RPM 2200
Maximum RPM 5200
Valve Float 6500
