G'day guys,
I am changing the cam on my 85 305.
I bought a melling timing gear and chain set and when I went to install it, with the gear on the dowel pin on the cam located correctly and with bolts in the 3 holes in the cam finger tightened down I have slop on the gear side to side. The stock gear seats snug on the end of the cam into the recess in the back of the cam timing gear but this one has wiggle room. I haven't done this job before and don't know if thats normal or not. Seems to be that that amount of wiggle room would mean the gear isn't spinning concentric with the cam. I returned the melling gear set to the store and ordered a Cloyes heavy duty set but have the exact same issue.
It concerns me that both these sets have this movement on both the new aftermarket cam and also on the original stock cam that was in there originally. The fact the stock gear seats snug on the end of the cam makes me thing this is how it should be.
This is the Cloyes kit I am using.
Cloyes Parts
Here's a video of what I'm talking about. In the video i tighten the bolts and it does stop moving but thats only because the pressure of the bolts. It could still move around if I forced it.
gear slop
Cloyes Parts
gear slop
