You know guys, I can't explain why I want a little more power. Engine upgrades are last on my priority list. I'm working down my list bit by bit as money comes available. I've swapped out the transmission for a 700r4, built by a local company specializing in performance transmissions, to get overdrive. Eight MPG just is too much. I need to pop 10. It's my own doing; I swapped the 3.08 for a 3.73 and limit-slip awhile back and that's why. I can't say how much my motor has been modified as the guy I bought the car from did nothing to the engine and failed to get records when he bought the car at auction. I've had the car for barely a year. I've got headers, 3" X-pipe exhaust (I installed the 3", up from just under 2" when I got it). There's a Moroso oil pan and a serpentine setup with nice dual electric fans. It's got a Street Performer intake with a Holley 670cfm carb. I installed a Dakota Digital dash, cruise control and a couple of other modules, like tire pressure and so on. I put Hydro-Boost on the PB system. It's got front discs already. Right now I'm focused on the interior comfort. I replaced the AC with a Vintage Air because the vacuum switch in the control unit failed and that is the only part on the system unique to 1968 only, and no one makes a replacement. We tried adapting another year's switch, but that didn't work so well, so I bit the bullet since my only choice was a 52 year old part from a yard no matter what I did. I've replaced the front seat (sagging springs) and now I'm working on the stereo and other interior improvements. That's not all I've done, but this is already a long post. After the interior, I'll install an EFI, then a major suspension upgrade followed by 4-wheel discs. When everything is done, I'll tinker with the motor. I'd like to see around 500 HP or so, but I'm not upset with what I have now. So you see, I don't need anything much on the motor, I just want more power tuned for the street. I'll never take the car to the strip...well, probably I won't, but it could happen, just for fun. This is long enough. Sorry for taking up so much space.
Doc
