72 ss in park but cannot turn key to the off position to remove the key. Recently installed a new gm ignition switch that worked fine for months, any thoughts ?
try holding up on the shifter or turning the bowl on the column..
maybe the steering wheel lock rod is stuck..
sometimes rack/pinion just jumps a tooth from age..
It is both, that’s exactly what I was thinking and already tried before I looked back at this thread. That was it thanks for the input anyway. Working fine now, glad it wasn’t serious
is this
a column shift ??
a tilt column ??
