First you need the correct bracket and or plate for the Q-jet to make the Geometry correct. Theis bracket will do the TV cable Throt cable and if you have one Cruise control. If you use the wrong one or make one and its wrong you will have trouble.
Good source is Bowtie Overdrive they have adapters for all carbs
