my 77 el Camino was running fine but then when driving home from work the charge light came on so I took off the negative cable and it died so I had the alternator checked and it was fine so was the battery now I don't know what to do can someone help me with this
Does your Elco have AC ? I believe the fuse for the AC has something to do with the charging circuit (?) Don't remember .......
Of course the problem could be a number of other things, like wiring etc.
I'll take a look at the wiring diagram....
edit:
By the way, the red GEN light gets it's ground, for it to come on, from the alternator, when the engine isn't running. When the engine is running, and the alternator is working right, there is power on both sides on the light socket, so the light goes out.
Not sure how well the parts stores can check an alternator.
The wiring for the light is the brown wire in the small connector that is plugged into the back of the alternator, so check that plug and the wiring to it, and check if the plug fits tight etc.
Might be as simple as a dirty battery cable connection. It might look clean, I would remove the neg/pos connections clean then re install. Check your battery voltage while engine is not running. Start the car and you should see an increase of 1 volt if the alt is working correctly. Good luck, Pete :scatter:
Also the battery cable connection on the starter solenoid may be a thing to check....
You should have 12 volts on the red wire in the small connector on the alternator, when the ignition is on, & engine off, if I'm reading this diagram right....
Related Threads
El Camino Central Forum
892K posts
41.7K members
Since 2002
