1 - 13 of 13 Posts
Not a great description, but probably, run on. Run on is most commonly caused by a high idle speed. If you have a automatic trans, try shutting it off while still in gear.
anything from a bad motormount, to broken crankshaft! All good thoughts and suggestions so far, but your not giving us a lot to work with here.....
As said, not much to go on. It could even be something simple as an exhaust pipe rattle.
Take it to a shop and have it checked out otherwise we will only be guessing
Buzz
You're asking for help.. We're asking for more help to help you... If you can give more definitive information, I'll bet the help you need will be forthcoming.
My first guess is that you need to use higher octane gas, clunky could be your vehicle simply dieseling.
1 - 13 of 13 Posts
