Looking ahead, I am considering using coil overs on my Elky. Something like these: http://www.summitracing.com/parts/HAL-GE401-10450C/
Thoughts?
Thoughts?
I do have 305's tucked under with room for 335's.El Corvino, putting on a 305 and getting tucked up underneath the fender is gonna take some work, but will look sick.
That's Awesome! Nice Work!I do have 305's tucked under with room for 335's.
I have a mini tub in the rear all the way back to the inner wall. The front is all custom. Tubular A arms, 2" drop spindles, QA1 set up as well.
Here is the difference between before and after. Not exactly the same angle, but you can get a really good idea of how much space I gained.
http://i1139.photobucket.com/albums/n559/xmikextoomeyx/b6.jpg
http://i1139.photobucket.com/albums/n559/xmikextoomeyx/b9.jpg
http://i1139.photobucket.com/albums/n559/xmikextoomeyx/p10.jpg
http://i1139.photobucket.com/albums/n559/xmikextoomeyx/r9.jpg
http://i1139.photobucket.com/albums/n559/xmikextoomeyx/r12.jpg
If you click on my links below, I have pictures of all the before and after of everything I've done. Also, I like the benefit of adjustable coil overs because then you can change he ride height for your desired look or for a better launch.
