Last summer I re-did all the a/c stuff, converted to R134a with the later style r4 "pancake" compressor. Worked fine. Winter got busy, didn't mess with it too much. This summer, no cold air. Added dye and checked with uv light, found the leak, o-ring pinched. I finally changed that today, pulled vacuum, leak check held for 4 hours. Refilled with about 2.5 lbs of r134a while jumping the compressor. Compressor works great while jumping it and pressures read spot on. But when I hook the actual car's electrical connector and start up, the compressor never kicks on. Fuse is good. Anything simple I'm missing?
