So my machinist gave me back my block a couple weeks ago.
While painting it I found a crack between the threaded head stud hole, and the water jacket.
The crack runs right next to a mig tack, which was most likely a poor attempt at fixing a previous crack.
I don’t ever recall seeing the mig tack there before handing the block over.
So obviously the crack is an issue. But how big of an issue is it?
After over a thousand in machining, Is the block a throw away?
127596
did you get back the same block ??
can you ID it ??
did you do any marking on it before taking it in,
like main cap #s or anything else ??
a crack check/dye check/magnaflux is usually at the top on a 1000$ machinist bill..
are there any more cracks / imperfections in the block ??
is it a std. bore or .060 over ??
how much to fix by a pro-welder, that's done it ??
can you save it for a mild grocery getter build ??
Yeah, fortunately it’s the same block.
I probably shouldn’t have posted this hastily. It was a bad day.
But anyways. Builder said crack didn’t show up on magnaflux due to it being along a weld seam.
He’s going to helicoil, pin, drill some unrelated water jacket holes, and deck, all on his dime and asap. He’s a good man.
I just hope through heat cycles it holds up.
I would feel better if it wasn’t a performance build.
And I hope it’s a factory weld, and not done by a PO. Welding cast iron can be tricky and coin toss.
