1 - 10 of 10 Posts
I've tried pretty hard to decode the #'s on the front of the block, passenger side deck. Probably haven't found the right site yet.
F0308GT It is supposed to be a 327. .308 is the month and date, but can't find GT
Any help would be great.
Ralph
http://i1053.photobucket.com/albums/s466/hotrodelco/67011.jpg
decoding engine numbers on my '67
F - flint, MI plant
03 - March
08 - 8th day of month
GT - ??
JT - V-8, 327ci, 250hp, 10.5:1 comp, 4bbl carb, man trans, ti(transistor ignition)
note - all the "G" prefixes are for 6 cylinders, all "J" prefixes are for V-8's.
my reference: Car & Parts magazine - Catalog of Chevelle, Malibu & El Camino ID numbers (1964-87) published 1993 by Amos Press. page 7.
That's pretty much what I came up with. But it is a very distinct GT. Miss stamped at the factory?
Thanks, Ralph:???:
I got that listing from "Nasty Z28" and it also showed A.I.R. That looked odd to me because I did not think the smog pumps came that early. I had not looked at the picture in your post until after I posted. There is the pump. Good chance you have the mini mouse.
F - flint, MI plant
03 - March
GT - ??
Another comic book error - and that book is full of them. "Gx" suffixes (not prefixes) were used on quite a number of Chevrolet V8s as well as "Jx" suffix codes.
See http://chevellestuff.net/qd/engines/sb03_codes_d_hz.htm and http://chevellestuff.net/qd/engines/sb04_ia_zn.htm.
GT was used on a 1966 283cid., powerglide, 195hp, 2bbl, Full size car.
Get the casting number off the bell housing flange to see if it backs that up.
As well as 1967 283cid., Powerglide, 195hp, 2bbl, Full size car with A.I.R. A casting number would help narrow it down as would the casting date.
Try a dedicated Chevelle site such as http://chevellestuff.net. A.I.R. came on the scene in 1966 for Chevrolets.
Decoding engine nmbers
OOPS!! I entered info for a '64, not a '67. my bad.
Discussion Starter · #8 ·
More #'s
After loosening the bolts that hold the accelerator bracket and a little yoga, I have more #'s
Drivers side block reads 3849852
Passenger side, c46
Thanks for the help.:beer::texas:
Discussion Starter · #10 ·
That confirms my suspicion, My buddy tried to look up #'s while I was looking at it, and could not find any 327's with GT.
Kinda helps me decide whether or not it is going to gain CI.
:texas:
1 - 10 of 10 Posts
