DJenkins '68 el Camino
14357 Views 143 Replies 30 Participants Last post by  DJenkins
2
Big milestone! Finished dis-assembly and got the body and frame delivered for acid dipping.
Metalworks in Eugene, OR has a great rep and I was immediately impressed with the care they took in handling the car and parts during the drop off. They are going to do a great job!
Project will get a lot more fun from here on out as it is re-assembly with clean and/or new parts!
Year and Model: 1968 el Camino
Engine Specs and Modifications: Will be GM performance crate Big Block, probably ZZ502
Drivetrain Specs and Modifications: Will be Speedway or Currie 9 inch housing with 3:40 Posi. GM performance auto trans (probably - my son is trying to talk me into 5 speed)
Suspension Specs and Modifications: QA1 level 3 suspension package
Exterior Specs and Modifications: Will be stock(ish) sheet metal. Adding SS hood and badging. Black with white '69 style SS stripes
Interior Specs and Modifications: Stock black vinyl with upgraded buckets and adding console
Electrical Specs and Modifications: All new, upgraded wiring harness
129142
129143
See less See more
  • Like
Reactions: 3
61 - 80 of 144 Posts
4
Feels like good progress. Got the inside of the cab shot in SPI Epoxy primer.
I was going to shoot it Sunday, but then my son needed help putting brakes on his daily driver. Good Fathers Day stuff, worth the delay ;)
Here is what I started with in April of 2020 (rust city!) Yes you could step right through the floorboards, and WHT was that fiberglass patch on the trans tunnel o_O. And notice the nice dash mod, gotta love it:
138595
138596
Here it is with new sheet metal on the floor, dash, back of cab and the new trans tunnel for T56, all shot in SPI Epoxy primer:
138597
138598
See less See more
  • Like
Reactions: 5
Looks incredible! It's been fun watching your progress on this over the months.
  • Like
Reactions: 1
DJ,
What a great project & progress! A lot of talent getting put to use here as well. Not sure I'd know how to act with your facility/tools. Keep up the awesome work. Gabe
  • Like
Reactions: 2
DJ,
For 2 days I would just sit in his shop in a beach chair with beers and take it all in.
Tom
  • Like
Reactions: 1
Tom
Sometimes I do :cool:
  • Like
Reactions: 1
If you lay out sheets of sand paper and spray them with water, it's like sand under your feet.
Choose your beach wisely. 360 to 600 grit is comfy. 80 to 100, not so comfy.
  • Like
Reactions: 3
I've got a 90 lb bag of sandblasting sand that apparently we are not supposed to use anymore (silicosus risk) so I can just spread it around for the beach effect 😀
  • Like
Reactions: 1
DJ,
Thanks! Not sure about talent, I make sooo many mistakes, but I'm willing to learn and do it over if needed.
Having a nice shop was a lifetime dream. I held onto the dream, worked hard, and had good fortune. I am blessed!
  • Like
Reactions: 2
7
Got the seam sealing done and shot 2 more coats of SPI Epoxy.
That seam sealer is some messy, sticky stuff. Hard to make it look good! I used tubes and tubes of it, everywhere, and an acid brush to get it into cracks and to try and smooth it out.
139361
Then I shot the Raptor bed liner in the rear wheel wells. I like this stuff! Very easy to work with and I really like the texture and look of it.
It comes in 2 parts, the bed liner material and the hardener. The bed liner container is about 3/4 full and has a line, you add the hardener to the line, shake it up, screw the gun on and shoot it.
139355
Here is the gun to NOT get! I ordered a kit from TCP Global and it included this gun. Sounded great. The gun is a piece of crap! Get the one from U-Pol.
Notice the plastic trigger handle. It wobbles 20-30 degrees and comes off of the needle. Not fun to mess with when you are suited up, gloved up, with a respirator etc. Very frustrating! When I got the trigger in the right position, it shot just fine, but life is too short to work with crappy tools.
139356
End result was very good (despite the crappy gun!)
Here is another tip if you are thinking of using this stuff:
-They recommend a 60-minute flash time between coats.
-The material in the gun will catalyze in less than 60-minutes and clog the gun (ask me how I know this :mad: )
-After the first coat, spray some acetone or urethane thinner through the gun, then go smoke your cigar, drink a beer and wait to do the second coat.
139357
139358
139359
139360
BTW, this Raptor stuff has fumes! Of course I was all PPE'd up, but when I was done shooting I took the respirator off and nearly fainted! Strong stuff! Can still smell it while I'm posting this, 4 hours later.
See less See more
  • Like
Reactions: 3
5
Got the firewall painted, installed the gas tank (much easier with the car on the rotisserie,) plumbed the fuel and brake lines and then and put the body shell on the frame for the last time. Feels like a real milestone!
Having 2 cherry pickers to lift the body and wheel dolly's under the tires made this an easy, one-person job.
139711
139712
139713
139714
139715
See less See more
  • Like
  • Love
Reactions: 5
That is so cool! That was a huge day. Nice work.
  • Like
Reactions: 1
7
I decided a while back to re-skin the doors. The OEM Sheetmetal was just too hammered, especially the drivers door. The place where the door handle sits has a complex indent and lip arrangement and I just don't have the hammer and dolly skills to get that back in shape - it really was whacked. Plus the door skin had rust through on the bottom, which made me want to pull it off and see what was going on with the door frame. Good thing I did, as there was significant rust and damage hidden behind the skin.
After fixing the metal on the door frame (lot's of cutting and butt welding) I was ready to shoot the whole thing in black SPI Epoxy. Big moment!
Here is something that I'm sure all restorers come up against; as much as we want every square inch of metal to be perfect, rust free and solid, there is just no way to get every single nook and cranny to shiny metal before painting. At some point we have to say "I've done my best and we'll see how it goes."
I know the rust is stopped. The whole car was acid dipped and then the specific areas (after grinding off the skins) that still had rust were treated with Oshpo and meticulously neutralized.
Here is the prepped door frame:
140723
And painted in SPI Black Epoxy, 2 coats.
140724
140729
Also shot the inside of the new door skin in epoxy
140725
Some previous owner must have had the door open and backed into something because the mounting area for the door latch was bent all out of shape and the opening for striker to go through had had some "vice grip surgery." It was a mess!
I did my best to get it all back into shape with a hammer and dolly, and Dremel tool - I'm new at this and it was pretty interesting.
I think it is "good enough" for an inside surface and I may be able to skim it with filler and make it better before final paint.
140726
My first attempt at putting new skin on a door. Picky business . . .
But, got it crimped and spot welded on.
First test fit. Tweaking to the panel and door alignment still needed, but overall I'm pleased.
140727
140728
See less See more
  • Like
Reactions: 5
Nice work! Keep the pics coming!
It's looking great. You are doing an awesome job.
VERY NICE
yOU ARE ARE DOING A GREAT JOB
coming along nicely.
How did I miss this build?
Awesome stuff Dean. That is gonna be fantastic.
  • Like
Reactions: 1
Been awhile since I posted an update. I took a break from the el Camino and decided to do a "practice" paint job on my 2002 Suburban, kind of a warm up to doing the classic.
Here is a 5 minute video of the process and results:
Bonus - not only painted the 'burb, but got to play with the drone filming it :)
I'm back on the el Camino now and will have something (hopefully) cool to show in a day or so.
  • Like
Reactions: 2
Damn, that looks terrific Dean.
