1 - 20 of 20 Posts
usually when i get it the way i like it, i turn it to low, and leave it on heater. after a while i have to turn the hot/cold down to cold more, cause she gets to cooking :!: I was wondering if any of you have that same problem/delight :D .
Super Moderator
Sure do. Actually, the system is designed for full size G-bodies...everything from the two doors to station wagons. The fact that our cars have an even smaller passenger compartment is a plus. This is also a plus with the a/c system! When I decided to install an auxillery unit in my storage compartment, I installed an a/c unit without heat.
mine will run ya right out of the car. But I put a 195 degree in the winter and a 160 degree in the summer.
I thought about removing my heater core for summer because my air doesn't seem to cool the car as much as the heater heats it. I figure the air probably heats up a little as it passes over the heater core even though the heater valve is closed.
Super Moderator
I would suspect you have either a mis-adjusted temperature blend door, a leaking heater control valve, or your recirculation door isn't closing.
I just had my heater core out and the door at the bottom seemed to move freely.
The valve shpuld still be good, I went through it when I put it on.
My vents take forever to start blowing air through them, sometimes up to five minutes. Vacuum leak under dash?
My heater warms things up very quickly also and I end up dialing it in at about 60% on the "hot" side with the fan on the lowest setting. I sure hope the AC works that quickly in the summer too! :lol:
Super Moderator
Yes, because you still have hot coolant flowing through your heater core.
Deputy Director, Region 4
I had trouble turning down the heat in my '84 until I replaced the lever that connects the temp cable to the blend door. P/N 3037629.
My hot air blows when I have it on defrost but just regular air in all the other settings. I think I need to adjust the cable on the vent selector
during the summer time ,, i remove the heater hoses altogether on lumpy,,,use pipe plugs to plug off intake,,i dont have a heater control valve so it always blows hot,,,,so i just remove them,,no more hot air,,,cheers
A/c is for sissies. my windows roll down just fine :poke:
In the winter
heat on----window down
Even growing up in Idaho, I always had a window open in the car.
even at -15*
(need that outside breeze to circulate the warm air from the heater)
Here in Texas----one window is down 1/2 way all the time.
Truck now sitting in work parking lot with the window down-----37* this morning
Even with the AC on----usually have a sideglass down a couple of inches.
even though I have vacuum leaks and my heat only comes out the defrost vent it doesn't take but a minute or two to fill like i'm in Hades!
195 degree water is HOT!
When it gets hot in the summer I use the A (driver window) and the C (pass window). The floor vents keep things cool. The cupholder in front of the heater vent keeps my coffee hot.
My heaters in both will run you out of the cab, I just don't drive them much if any during the winter months unless it gets above 50 outdoors. I don't use any AC in the summer, just the wings in the 60 and roll the windows down in the 77.
PFlo/Paul:beer:
1 - 20 of 20 Posts
