1 - 10 of 10 Posts
Has anyone has used Duplicolor Rust Fix Rust Converter ???
I used it while the engine was out. Cleaned the engine bay and sprayed the stuff on everthing I could reach. It seems to work!
It is recommended to paint over the stuff with regular paint after it thoroughly dries. Some parts I didn't do that and they don't look very good. Not rusty, just not good looking. The stuff I painted still looks good.
Jack
Yep it is pretty good stuff. And like Jack_K says above....will even make black plastic inner fenders look nicer. Be sure to clean heavier rust away before using it.
The way I see it, if someone is looking close enough at the underside of my car to see spray paint, they're getting a size 10 to the nads.
:funnypost: I have used just good old fashioned rustoleum out of the can with a brush on things under the car, if you take your time and prep everything it doesn't matter what you use. When it comes to rust converters it's usually out of a spray can or a can. Most stuff like POR15 are not supposed to be sprayed in the first place. I have also had good luck with duplicolor products and would not hesitate to use them.
Spray paint is not going to look good because car paint is recommended. That stuff even sticks to plastic wow.
I and others were speaking of making them look better (inner fenders). The product you have inquired about turns to a black primer when it dries. Used on anything to be finished it needs real paint on top of it afterwards to be complete. It also works well by itself for light rust fix and a black after look on anything under your vehicle like the drive shaft you have started with here and much more...Brake drums, rear axle, frame and all.
1 - 10 of 10 Posts
