1 - 11 of 11 Posts
Can someone help me understand what these sensors do for the 305. Are they part of ECM system or independant? Thanks.
EFE CONT SWITCH AC DELCO #212-72-THERMAL VACCUM?
CNSTR PURGE SWITCH AC DELCO#212-232-KNOCK SENSOR?
CLNT TEMP SENSOR AC DELCO#213-928-AIR CHARGE TEMP SENSOR?
CNSTR PURGE SWITCH is broke off on manifold, charge temp sensor is broken at base is broken looks like wire that connects to it is not complete?
Have ordered above stuff to give ecm one last try before/if I replace with non ccc items.
Have read up on some ecm info but still learning. Thanks
no ecm s in 74. but to answer your question all of the sensors and switches connected to the ecm send input to the ecm to alow it to make the engine operate as effieciently as possible in both emissions and milage while improveing driveability
Sprint, of the sensors you mentioned in your first post, only the Coolant Temp Sensor and knock sensor affect the ECM as far as mileage and running. The others are there for emissions control and to burn off the fumes fro the cannister ( a good thing!).
The temp sensor is the most important one. Without info on the heat of the engine, the system will not go into Closed Loop. The knock sensor is there to retard the ignition if you start to get knock(ping). Otherwise, it is inert to the operation. It is important to have to protect the engine, as you can have knock and not hear it in the vehicle.
HelmInc.com
A little off topic, but I have found that the service manuals are often cheaper from Helm, then what they go for on Ebay. That is usually the way of auctions, people pay more than what something costs new.
1 - 11 of 11 Posts
