Can Intank Fuel Pump Run While Connected To The Manuel engine driven Fuel pump ???
I know this is an old thread, but I'm trying to figure if I have to do the same thing. 396 w/mechanical fuel pump and electric in tank pump. What do I replace the tank pump with?BOBBY 78 I am going mechanical fuel pump and have connected it up. But i need to disable the intank fuel pump without removing it .
Thanks for the info, JJ!you can replace the intank pump with a piece of 3/8" steel or copper tubing with a piece of hose and clamps to connect it like the pump,,
put a clamp around the tube at the bottom to hold it in place.. put a 90 degree bend at the bottom..
youll want a strainer of some kind at the bottom I built some from fine brass or stainless screen..
make sure you use hose rated for submersion in gas..
you could probably find someone swapping to efi to trade with you,, the intank senders are hard to find now days..
http://ts3.mm.bing.net/th?id=H.5004123266155482&pid=1.7&w=222&h=172&c=7&rs=1 or keep the intank pump and add a regulator at the carb,, then you wont need the mechanical pump,, may be easyer..
