My recently purchased '64 ELKY has an electric cooling fan in front of the radiator and does not have the traditional motor mounted fan and radiator shroud. It seems that it is more efficient becasue it is pushing air through the radiator vice pulling. My problem is that after engine shtuoff the fan never seems to shutoff. I end up pulling the wire off the battery + pole after letting it run about 15 min because I am afraid it will run the battery down. Can the fan be set (thermostat?) to turn off sooner? Can it be wired to ignition to shutoff when turn off motor? Any other suggestions? thanks in advance.
