1980SteelBeast
·Guest
Here's a short vid of what I've been up to.
Found out the wire going to the spade terminal on my starter is constantly hot while the car is off,which is draining my battery overnight. How do I bypass that?
Isn't the ignition wire suppose to stop all power to the starter when the key is in the off position?
Why is that wire drawing power? Even with the key off and removed from the ignition?:dontknow:
