well i finally got an F41 sway bar, and im going to buy some new endlinks/bushings before i install it. i was just wonder whats the correct size, or how to measure it.
The end links are the same as your old sway bar. The sway bar diameter is usually in millimeters. If it's a MCSS bar it's probably 32 mm (1.25").
The F-body hollow sway bar fits the G-body too. They come in 34 mm and 36 mm. They have a slight bend in the center of the bar where the 32 mm G-body bar is straight in the center. They are a bit lighter than the MCSS 32 mm bar too.
:mrgreen:
i was talking more about the endlinks, i was thinking it was around 3.5". but like i said i don't know where to measure from. if its the middle points or the outside
