http://youtu.be/XX99gr8mHIE
I have an 84 el camino conquista v6 229. My first issue was that the Fuel filter collapsed because someone had a rubber hose in line and caused a loss of fuel issue.Had road side garage repair it. Next the water pump went so upon replacing that i stripped the threads out on fuel line going to carb,and several people told me that i could not rethread this so i replaced the carb. I have been having issues ever since, engine bog, slow acceration. I had a mechanic adjust the carb,everyone seems to think it is running fine. It has no "get up and go" so to speak.I put pedal to floor and there is a pause, than it gradually...and i mean gradualllllly it picks up speed but extremely slow acceleration. Ive ran it like this for 6 months. now it has developed a "knock" or "tick". fyi: gas tank was replaced also,was leaking because of age.and exhaust was replaced prior to carb replacement.
Ive been told to take the catalytic converter off to see if lack of power issue changes? Im hesitant to do this because of the engine noise issue. also upon running the engine for 5-10 min the hoses are extremely hot, but radiator doesnt seem as hot. I have checked the coolant reservoir, all levels are fine. very frustrated, dont know what to check next.any help would be appreciated.thanks:let_it_all_out:
