Ok, my 86 el co has been leaking oil for some time now. I have checked a lot of things out and it still drops oil on headers and smokes from time to time, not out exhaust pipe.
I have about decided it is the valve covers which are aftermarket cast aluminum and probably Chinese anyway,I'm looking for a set of factory valve covers as I got rid of mine to see if that fixes the problem, hopefully it will. It smokes a lot more when the engine is under a strain or high revving. I guess my question is that I suspect it is leaking enough to loose vacuum and my transmission has begun shifting differently and causes the car to seem to run rough. Does it sound plausible that it could be loosing enough vacuum to cause shifting problems?????
thanks
thanks
