Finished rebuilding my engine and performed dyno test. In my four runs, power was consistent and peaked at 246 hp and 333 ft-lbs at the rear wheels. I was hoping for more. Below are the specification of the rebuild. This was my first attempt to rebuild an engine. Request input to unleash the rest of the potential in this engine! Should I just change the Carb or bolt on a Blower?
Block: SBC 400, 2 bolt main, bored 30 over to total displacement of 406. Casting number: 3951509
Rods: Stock
Crank: Ground and polished 0.010”
All bearings replaced with Sealed Power bearings; cam, main, rod
Pistons: Dish, with four valve reliefs, Hypereutectic aluminum, +12.50 cc/piston. SLP-H601P30
Edelbrock Top End Kit 2022. EDL-2022
a. Cam: Hydraulic Flat Tappet, Advertised Duration 278/288, Lift .420/.442
b. Heads: E-Street, Aluminum, 64cc Chamber, 185cc Intake Runner, 60cc Exhaust Runner, 2.020in Intake Valve, 1.600in Exhaust Valve
c. Intake: Performer EPS, Dual Plane, Aluminum, Square Bore
d. Timing Chain and Gear Set, Performer-Link, Double Roller, Iron/Steel Sprockets
Rocker Arms: Proform Parts, Stud Mount, Full Roller, Aluminum, 1.5 Ratio. PRO-66914
Push Rods: Edelbrock Hardened Steel, Heat-Treated, 5/16 in. Diameter, 7.900 in. EDL-9629
Carb: Edelbrock Performer, 600 cfm, square-flange, electric choke.
Hedder: Hedman Hedders, Street, Full-Length, Steel. HED-68310
Exhaust: Dual, no cat, free flow mufflers.
Distributor: Pro-Billet Ready-to-Run, Magnetic Pickup, Vacuum Advance. MSD-8360
Coil: Blaster 2 Coil. MSD-8202
Plug Wires: Super Conductor, Spiral Core, 8.5mm, Red, 90 Degree Boots. MSD-31359
External Damper: Harmonic Balancer, SFI, External Balance. SUM-C4266
Flexplate: 168-Tooth, External Engine Balance, 2-Piece Rear Main Seal, SFI 29.1. SUM-G101SFI
Fuel Pump: Stock 1984 305ci pump.
Water pump: Mechanical, Long, High-Volume. SUM-311006
New alternator, stock A/C unit installed.
Transmission: Bowtie Overdrives 200 4R level 2, 2200 rpm Heavy Duty torque converter.
Rear Differential: GM 7.5” 3.08 open.
Rods: Stock
