I just completed installing a choo choo front end - honest charlie fiberglass one. It seems to me that the car is running warmer based on the temp gauge. The car does not have the lower plastic air defletor on the front below the radiator.
Im trying to figure how to get the temp down - it used to run at 200 degress, now im at 220 -230 degrees.
I have put on a new water pump, all hoses, new thermo stat 195 degree, cleaned and flushed the rad, cleaned the ac condensor, new rad cap, and fan clutch - all of these were done as part of the resto im doing.
Should i install the lower air dam on the car (the choo choo nose does sit lower than the air dam or at least at the same level. Any other suggestions - am i missing something?
Appreciate the advise
