Most any small block v8 will fit. I am not sure about the transmission you have now if it will bolt to a V8. The 200r4 Automatic should have the bolts to bolt to any GM engine. I am finishing up a 350 w/200r4 trans in my 84 now. It had the 305 that was burning oil and such. Do you plan on keeping the computer controlled stuff or changing it out too? Mine had all that taken off and a reg carb and HEI Dist already installed when I got it. You may have to move motor mounts on the frame to accomodate the V8 do some measuring and maybe some others will chime in on here and give you some advice. There is a ton of it out here.
