1 - 3 of 3 Posts
Temp gauge not working when I bought the truck. I pulled the lead from the switch/sensor, let it idle for a few minutes to build a little heat, then measured the resistance at the switch. It was 394 ohms, anybody know if this is in the ballpark for normal operating temp? I orderd a gauge from El Camino store, should be here in a few days.
Thanks,
Don
welcome Don
you can ground the wire to the block and check the wire/gauge/power, it should go full hot..:texas:
also i was lookin for that info a while back,
i think this is what your lookin for,, there not the book readings,, its from someone testing a sender
its a TS-76 standard Stock 1/2" sending unit is "72-88 ohms @ 220 degF"
degF Ohms
220
210 94
200 100
187 118
180 128
170 146
160 168
150 194
140 225
130 259
120 298
110 346
100 410
66 707
the thread> http://www.camaros.net/forums/showthread.php?p=1024554
the sender>
http://www.discountautoparts.com/item.wws?sku=TS-76&itempk=125779&mfr=STANDARD MOTOR PRODUCTS&weight=5
1 - 3 of 3 Posts
