I have a 350 4 bolt in my 72,and looking to add abit of HP on a budget.Im unsure of the bore of the block,and believe the cam to be close to stock.What im asking is....Is it possible to get some more HP out of it without boring it out and replacing pistons,crank etc.It seems to have good oil pressure,and the only smoke from the engine is worn valve stem seals(first start up) Ive just bought a edlebrock perfomer manifold,to replace the professional products...carby is a holley 600 vac sec,and a streetfire dizzy,with hooker super comp headers.....What id like to know is,can i replace the heads..with something like this.http://www.summitracing.com/parts/DRT-127122/..and the cam with ??..http://www.summitracing.com/parts/LUN-60102LK/..(do i need roller rockers and a stall converter,or can i use my stock parts ?).Unfortanetly,at this stage,i dont have the funds to do bottom end work,(very expensive in OZ). Am i going to gain anything from these parts ,i understand,to make power,its a combination of EVERYTHING,but,Im not looking for a SCREAMER,just abit more punch than my smog motor has to offer.Or would i be better off buying a crate motor,from the likes of summit... selling what ive got to recoup some of the cost..http://www.summitracing.com/parts/MLL-BP3830CTC1S/.....Its http://www.summitracing.com/parts/MLL-BP3550CT/or this.. very hard to make a decicion from the other side of the world:dontknow: ....Id like to just go B/BLOCK,but not all that cheap here either...ADVICE PLEASE
