does anyone know where I can find a 86 ElCamino tach filter harness wire from distributer to tach wire on a factory tach ? Part #14062505 or #14062504, Ron
So, once you either make or buy this tack filter, where do you install/run the connections? My '87 does not have an HEI distributor with coil in the center of the cap. Also, if you salvaged a tach filter from another vehicle, is there a test to check if the setup is working properly. Thanks in advance.
Here is the link to the schematic. I just bought the parts on ebay.
Here is a pic of the one I built. Not my finest work, but I insulated the heck out of it with heat shrink.
129703
