does the frame hang lower than the body on a 85 el camino? and is so how much? thanks
8 85' · Registered Joined Mar 14, 2012 · 5 Posts Discussion Starter • #1 • Mar 14, 2012 does the frame hang lower than the body on a 85 el camino? and is so how much? thanks
Matty man · Registered Joined Apr 1, 2009 · 2,590 Posts #2 • Mar 14, 2012 Yes,, by an inch or two,, I am at work so I cant measure my 80,, I can do it in the next day or so,, Matty man
S speedy86 · Registered Joined Mar 8, 2004 · 1,559 Posts #3 • Mar 14, 2012 x2 the frame is lower by a couple of inches.
ccc · Registered Joined Feb 24, 2012 · 2,102 Posts #4 • Mar 14, 2012 yes 1 1/2in from the bottom of the frame to the bottom of the seam on the rocker panel
Bobby78 · Deputy Director, Region 1 Joined Sep 15, 2006 · 2,566 Posts #5 • Mar 14, 2012 Unless your body bushings are worn out and the body is resting on the frame.
8 85' · Registered Joined Mar 14, 2012 · 5 Posts Discussion Starter • #6 • Mar 14, 2012 thanks everyone for the help. i appreciate it
