Hey guys. Noticed ny fan shroud has a ton of clscrew holes with no screws? Its going onto the top of the radiator underneath but the holes arent drilled into the radiator? Are there bolts for support on top of the shroud? If so im missen them.
Can you guys send pics of your 5th gen radiator/shrouds cause im confused.?
And the plastic top of the shroud moves a bit as if its not flat on the radiator????
Thanks guys, just need to make sure on some things. It has been in a fenderbender somwhere along its life, just dont know if repairs were done correctly. The whole front drivers side has been replaced assuming radiator too.
Brandon
Brandon
