I have tried to search for the correct configuration for the front lights, turn, marker, side lights. I am not sure which are supposed to come on when? 1984 El Camino. My problem is which position are the turn signals (inboard or out board), same with markers and side lights, I have nothing to compare to.
Deputy National Director
turn signals are inboard ! next to grill
Headlights - the low beams are the outer & when the brights are on all 4 are on
front side marker blink with blinkers & rear's do not blink
front & rear markers on with lights on
Discussion Starter · #4 ·
Answered my own question. The front lights will not operate correctly, due to the fact that if they are switched from incandescent to LED (Light Emitting Diode) is the fact that no reverse voltage can a cure, because a diode only always voltage to travel in one direction.
@Huntn4Meat, I recently installed the H4 conversion kit from DixieRestoration. Very satisfied (I can see!) over stock sealed bulbs, wired directly to battery via relay of course. No issues at all with install.
LEDs are cool...like interior dome light...but I like old school.
