'78 Caballero... (Rally Gauges) Ok, I just put a brand new fuel sender in from OPGI. It is the correct level sender for my vehicle 22 Gal tank. I did some quick initial checks. I found 8.9-9 Volts and 30 Ohms resistance in the power wire going to the sending unit. To me, I'm assuming it should have 12V and I have high resistance cutting that to 9V causing the gauge to not read full. Does this sound correct? FYI... the gas gauge has never worked for me since I have owned the vehicle. I finally replaced the level sensor assy and this is now where I am at with it.
Thanks in advance!
Thanks in advance!
