1 - 9 of 9 Posts
Do you know how many PSI the engine was running on in the donor vehicle? In-tank would be preferred, but if you do frame mount, there are many options..... Summitracing.com
Walbro 255 lph pump is used a lot. need at least 50 psi.
if you have an intank pump just buy the replacement one for the corvette/camaro 350 tpi,about the same year as the engine
1 - 9 of 9 Posts
